Fuel Additives - Club Touareg Forums
post #1 of 20 Old 08-12-2011 Thread Starter
Jonmedic's Avatar
Touareg: 2011 V6 TDI
Fuel Additives
Should I be thinking about fuel additives for this winter?? This TDI is the first VW diesel I've ever owned. I know that in most of the ambulances I use we have diesel engines and we have to use an additive in the fuel to keep it moving at -45 C. Hopefully someone here has some experience with the 3.0 TDI and can help me out here with some info.
2009 Passat CC Sportline
2010 Tiguan Highline
2011 Touareg TDI Comfortline
Jonmedic is offline
post #2 of 20 Old 08-12-2011
You definately want an anti gel additive. I'm sure the dealers in Canada use them all the time. I had a diesel stand by generator that had to have the stuff even with a block heater. JP
tadpole is offline
post #3 of 20 Old 08-12-2011
The Moderator!
Yeti's Avatar
I have put nothing in my tank to two winters I have had my TDI. Winter fuel here already has the additive in it already. I have never experienced any issues what so ever and my TDI has been in some pretty cold temps while up skiing in the moutains.
Yeti is offline
post #4 of 20 Old 08-12-2011
SamTrooper's Avatar
I've always used Additives in my TDI's. I had one bad experience and that was it, tank freezing solid at -50 degrees years back and getting stranded at the side of the road. I use Optilube XPD winter formula for my 3.0 TDI, and power service for my 1.9 TDI year round. The optilube is good as well because it protects the engine from DRY diesel which can really kill the lifespan of your HPFP(high pressure fuel pump)... So you kill two birds with one stone..
Opti-Lube Advanced Lubricants
there's a link on there for a canadian distributor, but you'll probably have to call.
SamTrooper is offline
post #5 of 20 Old 08-12-2011 Thread Starter
Jonmedic's Avatar
Smile Sharing is good.
You see, this is why I love this forum. I posted this this morning as a curiousity type question and already I've gotten all of these responses and recommendations for product to use.OUTSTANDING!!!!!! I was talking with a friend the other day about a similar subject and it applies here as well. You never see two Windoze users who are total strangers sharing tips and talking about their computers but Mac users do it all the time. I've never seen two GMC or Ford users sharing info and tips like we do here either. I'm just sayin'.........
Jonmedic is offline
post #6 of 20 Old 08-12-2011
The Moderator!
Yeti's Avatar
You sure your diesel fuel does not already have the anti gel in it over the winter? I know it does down here and we get less mpg out of the winter fuel then we do our rest of year fuel. I have never added anything to my tank here or had any issues with it. You may want to check with your station this winter to see if there is something already in the fuel. Would suck to spend the money on an additive if you don't need to.
Yeti is offline
post #7 of 20 Old 08-12-2011
SamTrooper's Avatar
Stations are required to have additives in thier fuel but in canada, you can travel long distances where the amount of additive required would be much more than what is in a particular service station(at a more southerly station), effectively running you into another range of temperatures. The same thing can happen if you tend to drive few km/miles a month and drive into a drastic temperature drop. Plus the addtives that are in the fuel stations varies greatly. I got my Diesel from a flying jay(whom I now boycott), and they insisted their fuel was treated. When my car was towed to the dealer, they showed me I had a tank that was a frozen block of ice. Better to be safe than sorry.
post #8 of 20 Old 08-12-2011
CADman_ks's Avatar
Around here, our fuel is indeed mixed, and like you, we get poorer fuel mileage while it's mixed.
There might be a standard for mixing fuel, but around here, if you ask how cold it's good for, you'll get a LOT of varying answers. The general wisdom, however, seems to point to about -20F for our mixed fuel. The other thing that's impossible to find out, is when stations start mixing around here. It's usually accompanied by a rise in price, but you have to watch it every day to tell when it actually goes up.
Last winter, we made it to -10F a couple of times, and while I was worried about it, the car always started, and we never had any issues, so it's good to at least that around here.
Back in the day (mid 80's), my parents had several of the GM diesels, and gelled one once, and SamTrooper is right, it IS a B...
CADman_ks
2011 Touareg Lux TDI
Black / Saddle Brown
CADman_ks is offline
post #9 of 20 Old 08-12-2011
nickm's Avatar
Winter diesel does have anti-gel in it from the fuel distributors, but I use power service additive when I'm expecting temps below -20C or when travelling north.
There's only one way to de-gel a diesel and that is to let it sit in a heated garage until the completely waxed up fuel all turns to liquid again....much easier to drop in a $3 bottle of power service when in doubt.
For typical winter temps in the 0 to -10C range, I've never considered using an additive.
--PREVIOUS TOUAREGS:
nickm is offline
post #10 of 20 Old 08-12-2011
CADman_ks's Avatar
Does it actually have true anti-gel (like Powerservice), or is it a mixture of #1 and #2, or possibly some kerosene added in there?
There used to be a great "old" service station here that I bought fuel from. It was one of those last of the breed old time station owners, where they still had full service, and washed your windows and checked your oil while filling. I'd often talk to the owner while waiting for my fill-up, and when it got colder, I'd always inquire about when they were getting "winter" fuel delivered, and he'd tell me when the refineries started "mixing".
He always claimed that it was a "mix" of #1 and #2, and that may be the way that it around here, but we don't really have the need to get to super cold capable fuel. So, I just always assumed that it was a mix, and not an additive, but who knows...
CADman_ks
fuel additives??? Dennis Christman Drivers Lounge 13 05-23-2011 11:07 AM
Fuel additives to protect your HPFP? SamTrooper Drivers Lounge 14 03-06-2011 12:46 PM
New Fuel Pump Fuel Gauge not working hoss General Maintenance & Repair 17 01-03-2011 03:26 PM
Fuel Additives mickmackinbiker General Maintenance & Repair 7 09-28-2010 06:13 PM
Graduated Bottle for Diesel Additives Depiry General Maintenance & Repair 4 03-26-2005 11:39 AM
