ESP Sensor? - Club Touareg Forums
post #1 of 13 Old 02-18-2013 Thread Starter
Fonzi's Avatar
ESP Sensor?
My ESP (the triangle with the circle around it) is on all the time now. I don't know if it's because it's cold out side and it's trying to tell me to drive with caution but it won't go off, sometimes after a good hour of driving or so, with a few shut downs/start ups it goes away.
But I also have a Brake Workshop warning sometimes, I got a "ESP Sensor" code when I checked it. Any ideas?
Edit: A bit off topic, but where could I find some chrome wheel caps that cover the lug nuts? I found some on eBay but they're ridiculous, it's around $10 for a cap. I got around 5 for $4 at the dealership but they're a bit far away.
Fonzi is offline
post #2 of 13 Old 02-18-2013 Thread Starter
Fonzi's Avatar
And yes, my buttons are sticky (I guess the previous owner spilled something).
Fonzi is offline
post #3 of 13 Old 02-19-2013
Second Vehicle: 2005 R5 TDI
What was the code you got??
dragline1570 is online now
post #4 of 13 Old 02-19-2013
themedic's Avatar
Touareg: 2008 V6
i had to replace a steering sensor for my esp, my guess would be how easily can you slide out.
themedic is offline
post #5 of 13 Old 02-19-2013
If your fault code is something like "esp sensor module g419," then there may be a defective or disconnected sensor module... I just had to replace mine because the esp light was constantly on, along with the hill descent light. With the sensor not working, the vehicle's esp system shut off, so I had no abs or traction control. Realized that in the driveway when we had a bit of snow.
If you have or know someone with a scanner, I would run it to see what fault code shows up, and whether there is a consistent history of that code. Or take it to a dealer to see if they can diagnose the particular (my dealer charges a fee to do this). If it is something different than the "g419" module, then I really wouldn't know what's up. When I was trying to see what the issue was on mine, I saw another of other posts where the same light was caused by a different issue... so it may be something completely different.
These modules are pretty pricey new from VW (600-700+), but you can find them online used for around $150. It is a Bosch sensor module, and I believe it is also used for the Cayenne and the Q7. The module itself is located underneath the center console, which was very difficult for my mechanic to remove (believe you have to take apart the arm rest, etc...). Once you get to it, it just plugs in.
Here is a link to a unit like the one I purchased..
04 05 06 07 VW Touareg Accelerometer ESP YAW Sensor Control 7H0907652 | eBay
I'd definitely run the scans first to try to nail down the issue.. good luck!
Tonys04 is offline
post #6 of 13 Old 02-19-2013 Thread Starter
Fonzi's Avatar
I erased the code, is it normal for it to come on in the cold? It was a bit warmer today and it didn't come on.
Fonzi is offline
post #7 of 13 Old 02-19-2013
I did not notice that, but perhaps different things can cause the same symptom. Did you get the "g419" error?
Tonys04 is offline
post #8 of 13 Old 02-21-2013 Thread Starter
Fonzi's Avatar
I can't recall. I remember "EPS Sensor ______". Is there a trick to cleaning the sticky buttons? I don't want to pour rubbing alcohol over it or anything if it's not safe.
Fonzi is offline
post #9 of 13 Old 02-21-2013
Try electrical contact cleaner.
post #10 of 13 Old 02-21-2013 Thread Starter
Fonzi's Avatar
^ Thank you.
Fonzi is offline
