Error lights - Club Touareg Forums
post #1 of 7 Old 09-07-2013 Thread Starter
Error lights
I know and have read a bunch of posts and my mind is spinning. Got an 04 TDI , had been sitting for 5 months driven periodically , sat for month and now "Brake Fault Stop Vehicle", Fault Running Gear Workshop, Exhaust Workshop. First thing i did was check batteries, back one was fine , front one was not so I replace it, as soon as i start it up codes above start again. What would be suggested next , wire harness at seat?
Thanks, Brett
Amg_only is offline
post #2 of 7 Old 09-07-2013
Touareg: 2004 R5 TDI
Clear the codes with VAG-com
2006-VW Touareg 2.5 TDI,174hp.Manual Gearbox. Full,except the air suspension.
1996-VW Golf 3 1.9 TDI estate
2004-BMW 525d-fully loaded
1998-Land Rover Freelander 2.0 Diesel
Touareg MNE is offline
post #3 of 7 Old 09-07-2013 Thread Starter
Right now I can't drive it, Is that a dealer only thing?
Amg_only is offline
post #4 of 7 Old 09-07-2013 Thread Starter
Is there a way to reset the system? Good / not good?
Amg_only is offline
post #5 of 7 Old 09-07-2013
No, you can get one.. Ross tech, search for it here..
post #6 of 7 Old 09-08-2013
Thanks, Brett
If you have two batteries, then have you got a V10 and not the 5 cylinder model as shown under your "name"?
post #7 of 7 Old 09-12-2013 Thread Starter
Problem Still Here
Got the Vag-com & KII USB, cleared all the codes lots of low voltage codes
As before stated I installed new battery, checked the wiring that corrodes (already fixed, soldered and shrink tubed), when started I get CEL, Suspension Light and the big BRAKE FAULT STOP VEHICLE, reran VC to this:
Chassis Type: A9 - VW Touareg NAR
VIN: WVGHH77L84D045346 Mileage: 186060km/115612miles
Address 01: Engine Labels: None
Part No SW: 070 997 016 R HW: 028 101 172 9
Component: V10 5,0L EDCG000AGMª2813
Revision: 5KO3 Serial number: VWZ3Z0C7130796
Coding: 0060575
Shop #: WSC 02147 444 84451
VCID: 2957F9F1837BB150575
5 Faults Found:
17082 - Sensor Reference Voltage C
P0698 - 000 - Too Low
Freeze Frame:
RPM: 0 /min
Torque: 363.4 Nm
Speed: 3.6 km/h
Bin. Bits: 00100000
Bin. Bits: 00000000
Bin. Bits: 00100000
Bin. Bits: 00100000
Bin. Bits: 00000000
18005 - Powertrain Databus
P1597 - 000 - Missing Message from Level Control System (J197)
Freeze Frame:
RPM: 0 /min
Torque: 363.4 Nm
Speed: 3.6 km/h
Load: 0.0 %
Voltage: 12.46 V
Bin. Bits: 00001100
Torque: 0.0 Nm
Torque: 0.0 Nm
18034 - Powertrain Data Bus
P1626 - 000 - Missing Message from TCU
Freeze Frame:
RPM: 0 /min
Torque: 363.4 Nm
Speed: 3.6 km/h
Load: 0.0 %
Voltage: 12.46 V
Bin. Bits: 00001100
Bin. Bits: 10000100
18057 - Powertrain Data Bus
P1649 - 000 - Missing Message from ABS Controller
Freeze Frame:
RPM: 0 /min
Torque: 363.4 Nm
Speed: 3.6 km/h
Load: 0.0 %
Voltage: 12.46 V
Bin. Bits: 00001100
Torque: 0.0 Nm
18053 - Powertrain Data Bus
P1645 - 000 - Missing Message from AWD Controller
Freeze Frame:
RPM: 0 /min
Torque: 363.4 Nm
Speed: 3.6 km/h
Load: 0.0 %
Voltage: 12.46 V
Bin. Bits: 00001100
Torque: 0.0 Nm
Torque: 0.0 Nm
Readiness: 0 0 1 1 1
Part No SW: 3D0 909 135 M HW: 5WK 470 26
Component: Kessy 6400
Coding: 0131304
Shop #: WSC 31414 000 00000
VCID: 2F6317E9BD9FDF60891
Part No: XXXXXXXXXXX
Component: ELV XXXX
4 Faults Found:
01315 - Transmission Control Module
004 - No Signal/Communication
01316 - ABS Control Module
01299 - Diagnostic Interface for Data Bus (J533)
013 - Check DTC Memory
00576 - Terminal 15
009 - Open or Short to Ground
Address 06: Seat Mem. Pass Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0701
Shop #: WSC 00000 000 00000
VCID: F7F36F89854F57A0911
No fault code found.
Address 08: Auto HVAC Labels: 7L6-907-044.clb
Part No: 7L6 907 044 F
Component: CLIMAtronic 2+2 X 2715
Coding: 0001030
VCID: 37732F8945CF17A0D11
Part No: 7L6 907 049 E
Component: CLIMAtronic FOND 3600
3 Faults Found:
010 - Open or Short to Plus
008 - Implausible Signal
00057 - Right B-pillar/Footwell Shut-Off Flap Motor (V211)
005 - No or Incorrect Basic Setting / Adaptation
Address 09: Cent. Elect. Labels: 7Lx-937-049-V1.clb
Part No: 7L6 937 049 L
Component: 2703
Coding: 0111838
VCID: 458F55410F23753053D
Address 11: Engine II Labels: None
Component: V10 5,0L EDCG000AGSª2813
Coding: 0060575
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 C
Component: 05 Airbag 8.4E++H01 0352
Revision: BB36963 Serial number: 00004122
Coding: 0012341
VCID: 234BEBD9E1576B001D9
Part No: 7L0 959 339 B
Component: BF-Gewichtsens. 005 0006
1 Fault Found:
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Mileage: 1048575 km
Time Indication: 0
Date: 2127.15.31
Time: 31:60:00
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 E
Component: Lenksäulenmodul 3301
Coding: 0000232
VCID: 418741511B0B59106F5
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 980 P
Component: KOMBIINSTRUMENT RB4 2935
Coding: 0023131
Shop #: WSC 02184 444 84392
4 Faults Found:
01310 - Level Control System Control Module (J197)
02053 - Control Module for Transfer Case (J646)
Address 18: Aux. Heat Labels: None
Part No: 7L6 819 008 B
Component: Standheizung E1MAC 0235
Coding: 0000030
VCID: 356F25815FC3E5B0C3D
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
Shop #: WSC 02134 444 64772
VCID: F0E15495E021009850B
5 Faults Found:
00778 - Steering Angle Sensor (G85)
Address 1C: Position Sensing Labels: 7L6-919-879.lbl
Part No: 7L6 919 879
Component: JCI PathPoint 1600
VCID: 0409884544998C38043
Address 36: Seat Mem. Drvr Labels: None
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
Address 37: Navigation Labels: 7L6-919-887-CD.lbl
Part No: 7L6 919 887 DX
Component: Navigation 0728
Coding: 0000002
VCID: 9F4367294D3FCFE0B91
Part No: 7L0 959 933 E
Component: 2N HSG 0201
Coding: 0000085
VCID: 3E7D3AAD6AF526E8127
Part No: 7L0 959 701 B
Component: Tuersteuergeraet FS 0201
Part No: 7L0 959 702 B
Component: Tuersteuergeraet BF 0201
Part No: 7L0 959 703 B
Component: Tuersteuergeraet HL 0201
Part No: 7L0 959 704 B
1 Fault Found:
01312 - Powertrain Data Bus
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 7L6 035 466
Component: 12K-AUDIOVERST 0108
VCID: F1E75191EB2B09905F5
Address 56: Radio Labels: 7L6-035-186-CD.lbl
Part No: 7L6 035 186 AX
Component: Radio 0728
Coding: 0005077
Shop #: WSC 02184 444 72603
VCID: 89171971E3BB5150F75
Address 68: Wiper Electr. Labels: 7L0-955-119-V1.clb
Part No: 7L0 955 119 F
Component: Front Wiper 2416
Coding: 0000004
Shop #: WSC 31414 000 376832
Address 69: Trailer Labels: 7L0-907-383-1D2.lbl
Part No SW: 7L0 907 383 E HW: 7L0 907 383 E
Component: ANHAENGERELEKTRONIK 8254
Coding: 0000002
Shop #: WSC 40907 551 00000
VCID: 366D228D42C5EEA8CA7
1 Fault Found:
00576 - Terminal 15
Freeze Frame:
Count: 0
Count: 0
Address 6E: Ctrl Head Roof Labels: 7L6-919-044.lbl
Part No: 7L6 919 044 G
Component: DACHDISPLAY 0530
Revision: 00600530 Serial number: 2009268.03
VCID: 3B7B33B979E733C0359
Address 75: Telematics Labels: 3D0-035-617.lbl
Part No SW: 3D0 035 617 B HW: 3D0 035 617 B
Component: Telematik NAR1 0104
Coding: 0076510
VCID: 1F43E729CD3F4FE0391
Address 76: Park Assist Labels: 3D0-919-283.lbl
Part No: 7L0 919 283 E
Component: 0E Einparkhilfe 0907
VCID: 38712CB548D118D8D8B
1 Fault Found:
Amg_only is offline
