engine light on!!!!!!!! 4 faults anyone? - Club Touareg Forums
Go Back   Club Touareg Forums > Club Touareg Technical Forums > General Maintenance & Repair
Old 06-06-2010   #1
Images: 8
18057- Powertrain Data Bus: Missing message from abs controller
p1649-008- Implausible signal - intermittent
18053- Shareware version. To decode all DTCs
p1645-008- Please register/activate- intermittent
16434 oxygen (lambada) sensor B2 S1: Heating circuit: Malfunction (open Circuit?)
p0050 - 004- no signal / communication
anyone know if these are major or they can wait? I mean the engine light did come on. Let me thanks allot people.
timotei is offline   Reply With Quote
Old 06-06-2010   #2
This is just me but I would reset the codes. Could be from a low battery also. You have a wide range of faults. Only the O2 sensor from the 3 would kick the light on.
2006 Col Red V8 Pkg 2
2003 Mini Cooper
2002 BMW 325CI
1985 BMW 325e
(formerly Itsaminivan)
1BadAssT-Rex is offline   Reply With Quote
Old 06-06-2010   #3
Images: 8
thanks i did reset it and just the O2 sensor came on does anyone know were that is located at?
Old 06-06-2010   #4
I havent specifically looked for the sensors while under there. I know we have 4 cats. Any autozone or car repair place would be able to tell you or google search it and maybe u might get lucky. If no one else posts up on here...post over on VWVORTEX. I am guessing its a secondary (closest to the rear) sensor since u didnt say it went into limp mode. In fact, I need to replace the secondary (Bank 2) O2 sensor in my Mini Cooper as soon as it cools down.
2003 Mini Cooper
2002 BMW 325CI
1985 BMW 325e
Old 06-06-2010   #5
sensor B2 S1:
Actually it tells you right there.....BANK 2 SENSOR 1. It will be the rear ones..just dont know the configuration. If they went by common sense...the would be the left rear...but like I said..just guessing without a manual.
2003 Mini Cooper
2002 BMW 325CI
1985 BMW 325e
Old 06-06-2010   #6
Images: 8
is this in the rear. meaning under my spear tire somewere or under the hood?
Old 06-06-2010   #7
Images: 8
i searched and there saying bank 2 is on the opposite of cylinder 1
Old 06-06-2010   #8
Sounds correct. Like I said, I would be guessing without a Bentley manual in hand. The O2 sensors are located in the exhaust system right before and right after the cats. They are super easy to replace..but expensive. I have had a check engine light on my Mini Cooper for over 3 years because I dont want to replace it...lol.
2003 Mini Cooper
2002 BMW 325CI
1985 BMW 325e
Old 06-07-2010   #9
Touareg: 2009 V8
There have been sensitivity issues with the older eggs O2 sensors that will cause a code. Check with your dealership -there's a software update to "disensitize" the system.
rarod58 is offline   Reply With Quote
Old 08-07-2011   #10
Images: 3
I have the same issue. I had it reset since i had a bunch of fault codes come up doto a week battery. Had the battery replaced and reset the check engine light but still came back. Mine comes up with a code P0050 - Which i found out is: HO2S Heater Control Circuit Bank 2 Sensor 1Oxygen sensor heater for oxygen sensors before catalytic converter
Since this is my first TREG and i'm learning as i go along, Does anyone know where its located, how much does it cost and can this be purchased at your local auto part store like auto zone, pep boys or online??
suave6565 is offline   Reply With Quote
fan running when engine off and check engine light on prosh General Maintenance & Repair 9 01-30-2010 02:53 PM
Can't shut off check engine light even with no faults? atikovi General Maintenance & Repair 4 05-26-2009 11:14 AM
engine sputter followed by engine light? 2eregg General Maintenance & Repair 19 01-24-2009 12:39 PM
V-10 TDI Engine Light hprotter General Maintenance & Repair 3 09-16-2008 09:35 PM
engine light jim Touareg Reviews 3 02-18-2008 05:17 PM
Upgrade your Account
» Auto Insurance
