Engine Fan always on, engine code p2181 - Club Touareg Forums
post #1 of 11 Old 11-20-2016 Thread Starter
Touareg: 2014 V6 FSI
I drive a 2014 Touareg V6 FSI and recently my engine fan has been on the entire time my Touareg is on. After a day or so a check engine light came on with engine code P2181.
I am guessing a relay or something electrical is out because I am having no issues with my actual engine temperature.
I have no idea where to start checking relays or where the fan relay module is.
Can someone please advise?
Thanks!
Mat93618 is offline
post #2 of 11 Old 11-20-2016
mtnride's Avatar
Touareg: 2007 V8
Second Vehicle: 2007 V8
P2181=performance malfunction in cooling system. Check G62, engine coolant sensor and associated wiring for corrosion.
Go to Ross tech .com, wiki button at top of page, type in fault code in upper right box. This should point you in the right direction.
mtnride is online now
post #3 of 11 Old 11-20-2016 Thread Starter
Do you have a link to a schematic that shows location of the g62 sensor?
Mat93618 is offline
post #4 of 11 Old 11-20-2016
VW-a-holic
Oregon TDI's Avatar
Not sure where you are but if you're in the US you have a 3/36 warranty. ?
Oregon TDI is online now
post #5 of 11 Old 11-20-2016 Thread Starter
65k miles unfortunately
Mat93618 is offline
post #6 of 11 Old 11-20-2016
VW-a-holic
Oregon TDI's Avatar
Aw crap. Sorry!
post #7 of 11 Old 11-20-2016
mtnride's Avatar
Touareg: 2007 V8
Water temperature sender, sensor is located on water pump. Vwpartswarehouse.com part # 06A919501A, #15 on schematic
post #8 of 11 Old 11-22-2016
Second Vehicle: 2007 V6
2014 VW Touareg has a 10 year 100k mile powertrain warranty, don't waist your time and go to the dealership and have a Certified VW technician repair your issue.
Bends is offline
post #9 of 11 Old 11-22-2016
In the photograph you are referring to it is located next to the water pump, however the G62 sensor is actually located on the coolant flange on the bulkhead side of the engine (opposite side water pump) and the photograph does not reflect this.
mtnride likes this.
Bends is offline
post #10 of 11 Old 01-10-2017
Hello I am having the same problem,did you get it fixed?What was the problem?I took mine to the dealer and they told me it was a soft wear update so I had it done.$120 for the diagnostics and update and now it has the same problem in less than 2 weeks.Thanks Carl
pensbuc66 is offline
