Drive Shaft Bearing - Club Touareg Forums
post #1 of 5 Old 09-11-2009 Thread Starter
Drive Shaft Bearing
One will definitely know when the DSB is bad. The symptoms are the loud intermittent squeeling, problems with shifting and vibrations at the center console. I had mine replaced this week for a grand total of $1334, I requested the dealership to give me the old drive shaft and they obliged. First of all you cannot order just the bearing you have to replace the whole entire shaft. Other vehicles use the same bearing, it is a pressed on bearing, to get it off you would have to cut the drive shaft, and have it re welded back on with a lathe, this is a costly procedure.
You can also buy one from Racks and Axles out of Indianapolis, IN. for $600 plus $100 core + s/h. The dealerships are charging around $1100 plus labor.
Our dealership told us that if we had found the shaft, they would install it for us, a little too late for us unfortunately, but hopefully someone reads this and does their homework before shelling out 1400 bucks!
****WARNING**** the drive shaft must be properly aligned or the problem will re occur quickly...
vwfrreak is offline
post #2 of 5 Old 09-11-2009
spockcat's Avatar
Drive shaft bearing problems are not new. The info about the company in IN has also been posted here before.
Touareg Audio Accessories - Keyless Start - Paddle Shift ==>
spockcat is offline
post #3 of 5 Old 09-14-2009
Touareg: 2004 R5 TDI
While replacing your driveshaft flex disc, you may find that you have to disassemble the rear part of the driveshaft. The problems in Drive shaft bearing are not new, these are possible at that situation.
usedcar129 is offline
post #4 of 5 Old 09-14-2009
Touareg: 2007 V10 TDI
I recently purchased a '07 V-10, and in joining this forum I have noticed the frequency of the drive shaft bearing failure posts. Mine only has 20K, so no problem with this yet.........
My question is this: is it possible to lubricate this bearing (before problems arise) in order to prolong its life? Could it be done as a maintenance issue -- like oil changes?
Just a thought, but since I haven't had to deal with it yet, I have no idea if it is possible/practical.
gkrebbs is offline
post #5 of 5 Old 09-18-2009
No you can't service this but it fails around 60-70K mark and there are companies that can fit a new bearing for half the price of a new VW prop or drive shaft.
Drive Shaft treg4me General Maintenance & Repair 120 12-27-2016 05:51 PM
Drive Shaft replacement Devoman General Maintenance & Repair 50 04-02-2016 01:27 PM
Prop shaft centre bearing evaalainejosey General Maintenance & Repair 58 03-25-2015 03:25 PM
Drive Shaft jrhegness General Maintenance & Repair 18 11-30-2010 10:22 AM
Drive Shaft I want old rear drive shaft $100 ajwaldrop Classifieds Archive 0 02-06-2009 04:14 PM
