DIY: Touareg 3.2L V6 Oil Change - Club Touareg Forums
post #1 of 12 Old 06-23-2007 Thread Starter
Tools Needed:
7 quarts of oil (I used Castrol 5w-40)
Oil Filter
Crescent Wrench for drain plug (Plug is 19mm)
36mm socket
Socket extension
6mm hex
T-27 torx bit
Procedure
1. Belly Pan removal.
There are 6 torx screws. Remove the rear most belly pan.
2. Drain Plugs
On your back looking up, the left black piece is the oil filter housing and oil filter housing drain plug. To the right it is the oil pan drain plug.
3. Drain Oil Filter housing
Using the extension and the 6mm hex socket, remove the drain plug of the oil filter housing. A steady flow of oil will come out for a minute or so. Replace the drain plug and tighten
4. Oil Filter housing removal
Use the 36mm socket and extension to remove the oil filter cap. Once this is removed, snake the housing cover and old oil filter out.
5. Oil Filter and o-ring replacement
Replace the O-ring from the bottom of the oil filter housing cap and pull the old oil filter out by pulling away from the housing.
Install the new oil filter by pushing it firmly back into the housing. Also note the new O-Ring installed.
Installation is reverse of removal
6. Oil Drain Plug Removal
Use a crescent wrench or if you have a slim 19mm socket to remove the drain plug. Remember, lefty loosy righty tighty.
Replace the drain plug and tighten. Replace belly pan.
7. Pour oil into the engine...you're done!
2000 B5 Passat 1.8T
2008 GTI
2008 Audi S4 Avant
schmove is offline
post #2 of 12 Old 06-24-2007
Vegas Matt's Avatar
Awesome write up and photos! Thanks!!
Matt
Bye bye Blue...
Vegas Matt is offline
post #3 of 12 Old 09-24-2007
Where did the picts go?
2005 Touareg V6 Stocker
coug0007 is offline
post #4 of 12 Old 10-11-2007
Lenny's Avatar
Hey repost the pics. I cant seem them
2006 Touareg V6 - Sold
2009 Audi A4 - Totaled (R.I.P)
2012 Touareg TDI Galapagos Gray
Lenny is offline
post #5 of 12 Old 12-01-2007
Send a message via MSN to HiLandR
Photo links don't work anymore! Send them to me and I'll host them if you like!
HiLandR is offline
post #6 of 12 Old 09-28-2014
Touareg: 2006 V6
This was posted a long time ago but I have a question as I am about to do it; my main question is:
1- is it not easier to remove drain the oil from the pain before draining the filter?
a member of the forum asserted that the oil shoots horizontally from the filter which seems messy and I can't think of a way to control that and direct the spurts towards a draining oil pan since the filter is located so high that an extension is necessary to access it.
How long did it last?
konquistador is offline
post #7 of 12 Old 09-28-2014
Perhaps a mod can reinsert the pics in the post.
I had saved this post locally many years ago when I had a beautiful shadow blue 2004 V6.
Name:	V6 Oil Change Pic 01.jpg
ID:	72241   Click image for larger version
Name:	V6 Oil Change Pic 02.jpg
Name:	V6 Oil Change Pic 03.jpg
ID:	72257   Click image for larger version
Name:	V6 Oil Change Pic 04.jpg
Name:	V6 Oil Change Pic 05.jpg
ID:	72273   Click image for larger version
Name:	V6 Oil Change Pic 06.jpg
Name:	V6 Oil Change Pic 07.jpg
ID:	72289   Click image for larger version
Name:	V6 Oil Change Pic 08.jpg
nickyt is online now
post #8 of 12 Old 09-30-2014
G6mdxvct's Avatar
Just changed my oil this weekend. I always drain the pan first. Oil shoots out horizontally further than you would think so don't put your catch pan right by the drain plug. I then drain the filter, oil comes straight down and should not go horizontal. I put my catch pan right below.
I don't even jack up the car. Probably easier if you jack up however have never had a problem getting to filter sliding in from the front drivers side.
G6mdxvct is offline
post #9 of 12 Old 09-30-2014
I recently purchased a 11 VR6 Treg and will soon need oil/filter change, can someone verify the 3.2L and 3.6L VR6 have same or very similar procedure for oil/filter change?
VWBobNY is offline
post #10 of 12 Old 09-30-2014
Touareg: 2007 V6
It's the exact same. They only real difference is the 3.6 have a power steering line that runs under the filter housing which just adds to the mess of draining and removing the filter.
My suggestion is use a piece of cardboard to direct the oil away from the steering rack and subframe when you drain the filter housing.
All of the tools needed are the exact same though.
3.6T-REG is offline
HELP PASS-SIDE HEADLIGHT TO CHANGE BULB TOUAREG V6 NON XENON no03330 General Maintenance & Repair 9 10-15-2015 11:08 PM
What would you change about the Touareg? Your Wishlist Mike General Maintenance & Repair 49 02-19-2013 11:26 PM
Oil change. SC-TOUAREGV8 General Maintenance & Repair 17 10-12-2007 05:01 AM
oil change bassbobh General Maintenance & Repair 7 05-17-2005 08:47 PM
$100 + for an oil change? fletch0776 General Maintenance & Repair 29 09-08-2004 05:08 PM
