Changed remote battery, now Keyless Entry doesn't work with any remote - Club Touareg Forums
post #1 of 10 Old 07-12-2009 Thread Starter
I was getting the "Key Battery Empty" warning on the MFI this morning, so I went and purchased a new remote battery. When I installed it and went back out to the car, it wouldn't open via the door handle or by hitting the unlock button on the remote. I used the metal key to unlock the door and start the car, which seemed to work fine, but now keyless entry doesn't work for either of our two remotes. Both keys start the car, and both remotes still work when you press the buttons. Previously (earlier this morning), both remotes worked every time, from any door.
Is there anything I can do to try to resolve this issue? Reset the computer somehow?
mega is offline
post #2 of 10 Old 07-14-2009 Thread Starter
Anyone? It's hard to believe that this is actually a hardware fault (from all of my searches on the forums, it seems the most common fix is to replace parts), considering it occurred when I changed the remote battery.
2004 V8 Touareg
mega is offline
post #3 of 10 Old 07-14-2009
My Keyless quit working just prior to having to replace battery.
New battery and no keyless operation.
I don't get it????
BonesNTX is offline
post #4 of 10 Old 07-14-2009
after installing a new battery in remote #1 (key battery empty warning), Remotes #1 & #2 keyless entry now does not work but fob buttons do work on both. correct?
are you still getting the key battery empty warning?
'05 PassatTDI, Reflex Silver, '10 TouaregTDI, Campanella White, '11 GolfTDI, Blue Graph. Metallic
'01 JettaTDI (retired), '06 TouaregTDI, Campanella White (retired)
CsTDI is offline
post #5 of 10 Old 07-14-2009 Thread Starter
Correct.
And I am not getting the key battery empty warning on either key now.
2004 V8 Touareg
mega is offline
post #6 of 10 Old 07-14-2009
Good.
In terms of the keyless entry, I have not encountered this issue, but my understanding is that if the little red light on the fob blinks when you use the fob then the battery should be fine. Assuming good batteries, after using the key once in the ignition, the transponder for the keyfob should be reinitialized. If the keyless entry is still not responding to the fob's transmission after this, I would say the problem does not lie with your keyfobs
CsTDI is offline
post #7 of 10 Old 07-14-2009 Thread Starter
The green LED lights up when I hit the buttons on the fobs, and the car responds perfectly to key presses. It's the keyless/buttonless access that's non-functional.
2004 V8 Touareg
mega is offline
post #8 of 10 Old 07-14-2009
and the non-response is occurring with both front doors and the rear hatch?
CsTDI is offline
post #9 of 10 Old 07-14-2009 Thread Starter
Correct, neither key works at any of the 5 doors.
2004 V8 Touareg
mega is offline
post #10 of 10 Old 07-14-2009
Mega, I don't see your location in your profile. You may want to update that and see if someone in your area can vag your Treg for a KESSY fault. I doubt all of the antennas went up at once
If it is still under warranty, you could have the dealer run the fault and look into the fix
CsTDI is offline
Remote Control Key Battery djbrimhall General Maintenance & Repair 40 09-26-2015 03:40 PM
Keyless Entry Door Handle Buttons Don't Work? briguy2186 General Maintenance & Repair 27 01-22-2014 08:54 PM
keyless remote problem Mangru-Man General Maintenance & Repair 3 01-21-2009 01:15 PM
remote battery tepiscopo General Maintenance & Repair 7 09-22-2008 10:28 PM
Keyless Remote ; Sticking door ; Gas Mileage ; Radio kaloisa General Maintenance & Repair 9 02-11-2004 11:43 PM
