I have a air-leak on my Treg.
It´s where the air-hose is connected to the "air spring damper". Between the "residual pressure retaining valve" and the damper. (front suspension).
Don´t wanna change the whole "air spring damper" because of a little leak. Same leak on both sides!
Someone must know how the parts are putted together!
VW-Sweden doesn´t know.
Is the connection between the "residual pressure retaining valve" and the damper a screwthread or is the connection squeezed together?????
Help!!!!
A damper change on both sides will cost me about 4200 $.
I hope I can fix it myself......just wanna be sure of how it´s putted together before I start destroying something!
Drawings? explanation? Something which can help me out?
VW Touareg 2003-03 V6
Best regards
/Jimmie
Help!!!!
Best regards
/Jimmie
